exhaust flange
exhaust flange
Does anybody know if the marina 1275 exhaust flange is the same size as a Morris minor flange , there more available if so or are they different sizes thanks for your help
Re: exhaust flange
Do you mean the clamp that holds the exhaust to the manifold?
Morris Marina Owners Club: Magazine Editor
Re: exhaust flange
If it is then the part number is: gex7284
I may have one in stock, but will need to check tomorrow for you.
Re: exhaust flange
The reason i ask my exhaust manifold does not have a servo pipe so is this an early manifold, or maybe it is not a marina manifold but a Austin manifold maybe
Re: exhaust flange
The Marina 1275 has a take off for the servo on the manifold. Part number: 12G3538 - eBay say it is the same as a mini: https://www.ebay.co.uk/itm/194208870696
Re: exhaust flange
Thanks for your help, did all marinas have a brake servo fitted then
Re: exhaust flange
Not all no. Certainly not in the early years. But the manifold would have been the same on cars with and without.
Re: exhaust flange
I have a number on the casting 12g2395
Re: exhaust flange
What year is the car? You could be right and it is an early manifold. You can use a later one and just block off the servo tap.
Re: exhaust flange
My original one was broke and this one is a replacement which is in good condition, would any size exhaust pipe fit like a Morris Minor, or does it have to be a Marina which are harder to come by. Thanks for your help
Re: exhaust flange
Minor exhausts are a smaller diameter as they are only 1100cc - Marina exhausts can be got hold of or even made brand new.
http://exhaustsuk.com/aboutus.htm
