Mgb exhaust
Mgb exhaust
Hey all.
During my current Estate rebuild a friend suggested that I should make it sound like an MGB.
Not a bad idea actually.
What I would like to know is how different is the Marina front downpipe setup as compared to mgb.?
Perhaps they are interchangeable.?
To my knowledge the mgb used a front muffler and a rear resonator.
Not sure if either or both of those were in any way special.
Having spent some time searching locally for mgb mufflers and failing, I am thinking that I need to involve mgb people.
Seems a bit of a comedown for a Marina owner....
Interested in anyone's insight.
Thanks.
Thanks.
Re: Mgb exhaust
The cast iron exhaust manifolds are essentially the same, the twin down-pipes on the Marina are slightly shorter than the MGB. The other variable could be the internal diameter of the main system could be different, which will produce a different resonance.
Re: Mgb exhaust
On my MGB The main silencer is just forward of the rear axle U bend It is a straight though silencer unlike the Marina offset one is also slightly longer from memory with a similar diameter ( I can check actual dia if required) the rear resonator box is again similar diameter to Marina one it is also again longer with down turned tailpipe i think both would fit though
Re: Mgb exhaust
The UK TCs with mild steel pipes and their original 'torpedo' rear resonator always sounded far better than any MGB I've heard or driven.
Isn't the MGB is a shorter car? That might have an effect on what it will end up sounding like.
Morris Marina Owners Club: Magazine Editor
Re: Mgb exhaust
My nieghbour's had a NZ new HL that sounded exactly like an MGB, wonder if NZMC specified MGB-style mufflers, since the exhaust system was made locally?
MGB forums say 1 5/8" ID (1 7/8" OD) tailpipe is standard, recommend 1 7/8" ID (2" OD) for a 100-120bhp engine.
http://www.superstreetonline.com/how-to ... w-exhaust/
Re: Mgb exhaust
Thanks for the info guys.
I have no idea what was originally fitted as all now seem to possess replacement items that often do not look as though they were designed to fit in the space provided.
Was the original front muffler on the Marina an offset type or were the pipes central both ends..?
Re: Mgb exhaust
Centre UK Silencer was offset with what looked like e perforated baffle inside
Re: Mgb exhaust
The MGB factory mid exhaust box in this shot from Bryan's link looks very similar to the RC40 as used on minis:
Obviously with straight in/out pipes. Now, they do sound nice on B series engines.
Re: Mgb exhaust
Not really relevant for the B engine, but this Marina 6 rear muffler system is for sale on ebay Australia (for $400!). Appears to be just the single muffler.
Nos Repco Leyland Marina 2.6L Exhaust Rear Muffler System M2859
Re: Mgb exhaust
my gt has no rear silencer just a straight thru pipe after the Swan neck sounds great!
Re: Mgb exhaust
I was running the same setup on the yellow car prior to removing the engine for use in the estate.
While it sounded pretty business, there was a harsh quality to the sound that did not please me, hence my idea that the use of a resonator might smooth the sound out a bit without muffling too much.
This was the old exhaust, which does not fit on the estate as the rear valance arrangement is different...
https://www.youtube.com/watch?v=FSTvNg4571E
Loud mechanical noise from the engine bay was the water pump announcing its demise.
Now replaced.
Now replaced.
