Radiator expansion tanks & windscreen washer bottle
Does anyone have any tricks of the trade to clean these items ?
My ones on the Jubilee are quite dirty
Can they be bought new from a supplier
Thanks
Gary
Thanks
Gary
2021 Jeep Renegade 4XE Hybrid
2022 Fiat 500E
1974 Morris Marina TC Jubilee
2022 Fiat 500E
Re: Radiator expansion tanks & windscreen washer bottle
I use Milton Fluid, used for cleaning baby stuff, together with glass container cleaning balls, which are little copper balls like lead shot, but reusable. I steal my wife’s ones that she uses to cleaning flower vases. The opaque/white plastic comes up a treat, just swill them round and then strain them off and rinse them.
You could try putting them in the dishwasher if you have one.
Try using bleach I used this many years ago on my expansion tank then rinsed it out
I put a brass one off a MGB on my car as I was concerned that not only the plastic was dirty but had gone brittle after 40 years of hot cold cycles and didnt want it to split the plastic radiator plug was changed to brass for the same reason
Hi David,
I realise this reply is a few months after the fact... You mention you changed your radiator plug for a brass one. Do you know where I can purchase a new radiator plug from?
Woody
Woody
Think I bought it off ebay from memory listed for a Land Rover
https://www.angclassiccarparts.co.uk/pr ... -mkii-7580
Here you go - mis-labelled as thermostat housing plug.
Cheers both - very helpful!
