						Post
								by locost_bryan » Mon Mar 08, 2010 10:32 pm
			dazza2623 wrote:I know we have gone off respray but will continue,The lowest that I believe you are safe from damage is 3".That is what the van & four door are set at.
The wagon has had the Aussie diff fitted ( ratio unknown ) & the front is still English but has had Leyland discs fitted.
The gearbox will be a 3sp auto & tailshaft will cope with the 8.
iirc Kilroy lowered his auto wagon 2" and the BW 65 has taken a few smacks and had the oil filler tube smashed off by a rock.  THink it hangs down lower than the manual box.
iirc the Aussie diff is either 3.89 (4 cylinder with one tramp rod) or 3.70 (6 cylinder with 2 tramp rods), but could have a non standard ratio.  Only way to be sure is either to take the cover off and count the teeth, or rotate the pinion and count how many times the wheel rotates.
																			 Greystoke
						Post
								by Greystoke » Fri Mar 12, 2010 5:14 pm
			We all use tractor paint to paint our rally cars, it's dead cheap, dries really hard and is easy to use. We regularily re-spray our cars and they look pretty good.
								MARINAMAN480
						Post
								by MARINAMAN480 » Fri Mar 12, 2010 8:10 pm
			Thats interesting will look into tractor paint  must be limited to colours tho?
																			 Greystoke
						Post
								by Greystoke » Sat Mar 13, 2010 4:25 pm
			Primary colours mainly, John Deere yellow or green, Ford blue etc etc
								MARINAMAN480
						Post
								by MARINAMAN480 » Sun Mar 14, 2010 11:09 am
			thats good john deere green would do the job well wonder were i can get some
								crashbang
						Post
								by crashbang » Sun Mar 14, 2010 10:36 pm
			lee if it for the green one dont spend to much or you wont drive it so hard and we will lose more time on a regularty
i remember you overtaking with the drivers wing deep in a hedge and two wheels up on the grass bank  :shock: good times
when are we out a gane?? are you going to the blackpalfy 12car tuesday me and mick are car1 but 7oak forum has got dave looking for a navigator
																			 Greystoke
						Post
								by Greystoke » Mon Mar 15, 2010 7:14 am
			It's a pity you rally chaps aren't up in Lincolnshire
